It is currently Mon Jul 21, 2025 3:31 am
 Post subject: Templates
PostPosted: Thu Nov 03, 2011 4:38 pm
If you guys were to buy templates, would you rather have 1/2 - 3/4" plywood or 1/4" lexan and pay the increase in price for lexan?
 Post subject: Re: Templates
PostPosted: Thu Nov 03, 2011 4:59 pm
For what, drawing outlines or routing templates for body shapes and cavity routes?
If drawing, I like the clear templates, for routing, I like to draw the outline with a clear template, then use a wood template as the bearing guide.
Old growth, shmold growth!
PostPosted: Thu Nov 03, 2011 5:15 pm
routing templates
PostPosted: Thu Nov 03, 2011 5:56 pm
State: AR
Lexan.
PostPosted: Thu Nov 03, 2011 7:40 pm
First name: Jamie
Last Name: Unden
City: Lakeside
Zip/Postal Code: 92040
Thicker than 1/4", though. That's not much for the bearing to ride on.
PostPosted: Thu Nov 03, 2011 8:20 pm
Buy the 1/2" plywood template. Use it to make a 3/4" plywood (or MDF) copy to use as a routing template and a 1/4" acrylic (plexiglass) copy to lay on your work piece to find the most appealing grain. When you mess up your routing template, you will have the original to make a new one.
PostPosted: Sat Nov 12, 2011 2:03 am
First name: Jim
Last Name: Hansen
I make my own from Foamed PVC from Tap Plastics...
Jim Hansen
PostPosted: Sun Dec 11, 2011 7:10 am
Layout? Acrylic.
Routing? Trespa (phenolic), which I can usually pick up cheap or free at building sites. Scraps are big enough for full guitar templates, and it is tough as nails. Do not need transparent templates for routing, as indexing off scribed centrelines (or indexing points) works just fine.
